Larry's Shee Posted May 7, 2015 Report Posted May 7, 2015 If they are 180, it's the wrong carb. They can't go 180 in the correct carb. Simple as that. 1 Quote
SHEEMAN0415 Posted May 7, 2015 Author Report Posted May 7, 2015 yeah i did one last night no leaks Quote
98_sheester Posted May 7, 2015 Report Posted May 7, 2015 Well if you passed jus make the the grooves are in toward the choke tube and your cutouts should face the airbox on the top Quote
98_sheester Posted May 7, 2015 Report Posted May 7, 2015 Cutout is to the rear facing the airbox on the top of the slide Quote
hoppedupandcutdown Posted May 7, 2015 Report Posted May 7, 2015 this cut-out, you can just pull the filter and see 2 Quote
98_sheester Posted May 7, 2015 Report Posted May 7, 2015 Both should be like this the groove on the inside and the cutout to the back and youll run like new Quote
SHEEMAN0415 Posted May 7, 2015 Author Report Posted May 7, 2015 cool guys thank you for the help i greatly appreciate it. Ill try when i get home from work and let you guys know if it works. Quote
do-work-son Posted May 7, 2015 Report Posted May 7, 2015 I didn't think they could go 180 in the same carb..if you switched them side to side then they get put in backwards. And floods the motor out.. Quote
SHEEMAN0415 Posted May 7, 2015 Author Report Posted May 7, 2015 yeah i know there in the right carb, hopefully one is just twisted Quote
98_sheester Posted May 7, 2015 Report Posted May 7, 2015 Ask long as it looks like the pics youll be good Quote
SHEEMAN0415 Posted May 7, 2015 Author Report Posted May 7, 2015 well ill tell you in 10 minutes or so:p Quote
SHEEMAN0415 Posted May 7, 2015 Author Report Posted May 7, 2015 Found it!!! LOL. Slides were in right, but they are way too high. How much clearance ahould i have? Sent from my iPhone using Tapatalk Quote
wayne_smith97 Posted May 7, 2015 Report Posted May 7, 2015 Find out why they aren't bottoming out. Slides should bottom out then take idle up from there. Quote
SHEEMAN0415 Posted May 7, 2015 Author Report Posted May 7, 2015 Bottom right out completely? Sent from my iPhone using Tapatalk Quote
SHEEMAN0415 Posted May 7, 2015 Author Report Posted May 7, 2015 Still to open? Sent from my iPhone using Tapatalk Quote
