600racer Posted April 25, 2015 Report Posted April 25, 2015 Ok folks I'm sure this has been gone over many times but just wondering what you guys think. I have a 4 mil LR with dune port, stock modded cages with carbon reeds, billet manifolds with crossover, k&n pods, t5s, cool head with custom cut domes running on premium. This is what I currently have in right now, 160 mains, 62 pilot, cel needle middle clip, air screw is only 1.5 turns out and the idle about 7-7.5 turns out. I have been told that a 62 pilot is too much just trying to get some more info. Quote
Sandking Posted April 25, 2015 Report Posted April 25, 2015 Try 50 pilot. The main seems too high but my experience is with a pwk carbs. I run a 150 main with a similar motor. Quote
600racer Posted April 25, 2015 Author Report Posted April 25, 2015 Ok as soon as it stops raining I'll do a plug chop Quote
trickedcarbine Posted April 25, 2015 Report Posted April 25, 2015 50-55 pilot. Air screw should be about 3/4-1 1/2 turns out. And 152-155 main. The idle circuit is just about always where you have it (7-71/2 turns) What needles are in them? Quote
600racer Posted April 25, 2015 Author Report Posted April 25, 2015 I have cel needle middle clip Quote
trickedcarbine Posted April 26, 2015 Report Posted April 26, 2015 Try it one clip richer. IMO they can be a bit finicky but if you keep them a touch rich they fair very well with only the occasional minor air screw adjustments. Quote
600racer Posted April 30, 2015 Author Report Posted April 30, 2015 How do you fellas upload pictures I have a plug chop ready for the viewing and I forgot to mention in my op I'm running +4 timing Quote
bigweav81 Posted April 30, 2015 Report Posted April 30, 2015 How do you fellas upload pictures I have a plug chop ready for the viewing and I forgot to mention in my op I'm running +4 timingTry tapatalk Sent from your mammy house Quote
600racer Posted May 1, 2015 Author Report Posted May 1, 2015 Ok I cannot figure this out so if anybody would like I can through my number up and i could just txt a picture that's if anybody would want to just let me know Quote
600racer Posted May 1, 2015 Author Report Posted May 1, 2015 If any of you goroos have Facebook I posted them on banshee nation, banshee riders and yamaha banshee 101 Quote
600racer Posted May 15, 2015 Author Report Posted May 15, 2015 I'll try this again plug chop turned out spot on with the 160 sand dropped the pilot down to a 55 and she ran ok since it wasn't completely dialed in I swapped out the stocker cages for the vf4s with the 55 pilots it falls flat on its face when I stab the throttle, I'm going to go up on the pilot I have 58s,60s and 62s and also which of the 2 needles do people have better luck with the cel or ceg I have both any help would be great Quote
trickedcarbine Posted May 15, 2015 Report Posted May 15, 2015 My 4 mil liked a CGL in the PJ's. Before that I had a finicky mid range on CEL's. This was on a dune port. Try the CEG's and see what it does. Also in my experience, i feel that with the way the choke is at a constant on the PJ's keeping them FAT helped it feel more responsive. Doesn't need to be blubbery rich, but you certainly won't need to lean them up to make them feel crisp off idle. Quote
600racer Posted May 15, 2015 Author Report Posted May 15, 2015 Ok I'll through the ceg needles in and try b4 I do any other changes Quote
600racer Posted May 15, 2015 Author Report Posted May 15, 2015 Threw the ceg needle in middle clip with 55s 160 main and air screw 1.5 turns out, terrible 0-1/4 bog played with clip nothing through 58s in same thing nothing through 60s in started to get better played with needle through 62s in got better clip is at the bottom clip with air screws 1 turn out should I get 2 more sizes of jets and try again Quote
BansheeUSA Posted February 22, 2021 Report Posted February 22, 2021 Did you find a solution I’m having the same problem with similar build. Quote
