arena314 Posted April 18, 2015 Report Posted April 18, 2015 Ok so I got an 03 banshee and the guy I got it from said it needs to be jetted bc it wasn't running right so I jetted it and tuned it and it ran perfect the only strange thing is when I was riding it and would let off the throttle it would stay at high rpms for a 5 to 10 seconds to go down to idle again but I didn't think much of it then after about 20 out of nowhere the rpms jumped like crazy and wouldn't stop climbing until I kill the engine and when I started it back up itb would do it again and again. I come to the conclusion that it may be a bad throttle cable but I really don't know. It has a tors eliminator kit so it's definitely not that. What do you think it is? Think it could be the fuel cable? Let me know. Thanks Quote
uman1030 Posted April 18, 2015 Report Posted April 18, 2015 you didn't mention what you changed the jetting to? This could be useful information if accompanied with a list of your engine mods and air filter style? Usually a maladjusted cable will raise the throttle when you turn the wheel if its too tight. More then likely jetting or an air leak. I would lean more towards an air leak if it is getting increasingly worse. Quote
98_sheester Posted April 19, 2015 Report Posted April 19, 2015 Are your carbs synced and are the slides in the correct way Quote
arena314 Posted April 19, 2015 Author Report Posted April 19, 2015 If they screw all the way Down doesn't that mean there in right? It seems to look like there in right Quote
bigweav81 Posted April 19, 2015 Report Posted April 19, 2015 Cut outs on bottom of slides should face airbox Sent from your mammy house Quote
arena314 Posted April 19, 2015 Author Report Posted April 19, 2015 Would you be able to send a pic of how they should look in the carbs? And if they fit in and screw Dien doesn't that mean there in right? Quote
bigweav81 Posted April 19, 2015 Report Posted April 19, 2015 Have you taken your carbs apart lately? Its simple to look down your air box, and see if your cut outs are facing you. No you can put the wrong slides in the wrong carb, and still screw it down....just go look. Sent from your mammy house Quote
arena314 Posted April 19, 2015 Author Report Posted April 19, 2015 They were apart when I re jetted them. And is the problem I'm having a result of the slides being in wrong? I can't check right now bc I'm not home to look at my carbs Quote
bigweav81 Posted April 19, 2015 Report Posted April 19, 2015 I just read through this. Sounds like an airlleak, could be jetting. If your slides are in wrong it will run like shit. Look everything over. Always a good idea to do a compression test, and leak down test when you buy something. Most of the time shady ass people will pass a problem off as something easy to fix. If it revs to the moon by itself, you have an airleak! Sent from your mammy house Quote
arena314 Posted April 19, 2015 Author Report Posted April 19, 2015 I was thinking that but I can get it to idle normally. I was riding it around and it would idle Down and idle all day then it randomly started doing it. It would ride fine but after 20 or so minutes of riding it happened. Quote
arena314 Posted April 19, 2015 Author Report Posted April 19, 2015 (edited) If it was a leak wouldn't it idle high the whole time? Edited April 19, 2015 by arena314 Quote
bigweav81 Posted April 19, 2015 Report Posted April 19, 2015 Ahhhhhhh fuck it! Ride it till she burns. Working on shit is over rated. Sent from your mammy house Quote
arena314 Posted April 19, 2015 Author Report Posted April 19, 2015 Well I'm going to check my slides in the morning and tighten Down all my clamps and if it still fucks up I'll run a leak down. I have vforce4 reeds fmf pipes uni air filter and no air box lid I ran a 300 main and 30 pilot Quote
sleeper06 Posted April 19, 2015 Report Posted April 19, 2015 Well jetting Is out if anything your rich,I'm going air leak. I would not ride it anymore till you pressure test it there is pics all over this site about . Needs to hold 6 lbs for 6 mins accept nothing else, or think you know what's wrong with it and burn it down trying to figure it out Quote
