aleyesonme Posted April 6, 2015 Report Posted April 6, 2015 It's been about 5 months now,I can't find not one review on these new pistons....the 11091M06800. I'm in the process of refreshing my motor. And can't decide should I try these or go for what I know, which is the blaster piston. 421 cub is what I have. If anyone has any input that used them, please share..thank you 1 Quote
trickedcarbine Posted April 6, 2015 Report Posted April 6, 2015 Not sure if they are intended for Cubs. PM BansheeHP. He is involved over there and can give you the answers you need. Quote
BANSHEE HP Posted April 6, 2015 Report Posted April 6, 2015 They intended for any cylinder using a blaster style piston. The pin height and dome profile are the same as a 573mo6800. They have been selling well. With a few positive review and no complaints. Youll see more results once riding season hits here in the next month. Quote
sleeper06 Posted April 6, 2015 Report Posted April 6, 2015 I have recently installed a set, I wouldn't hesitate to use them . The concept is there. And anything that will get a lil more oil to the wrist pin in a race motor is good. Most bikes that r set to kill can use all the help they can get after an all out pass Quote
sleeper06 Posted April 6, 2015 Report Posted April 6, 2015 As far as s review they are still running , I'll let u know in a yr when I re ring it Quote
aleyesonme Posted April 7, 2015 Author Report Posted April 7, 2015 Thanks so much for the replies. A whole lot of more info than I had before. Just wasn't sure if it was was worth the extra 30 bucks. Thanks again. One more thing, do you think the new ones would require rejecting....cause with the 573 I'm dead on. Quote
