2STROKIN_IT Posted April 4, 2015 Report Posted April 4, 2015 So I installed a adjustable timing plate on my 99 banshee but don't know where I set it?? Like what do I have look at to set the degree on it?? I assumed that the center line where the top and cases meet as my guide to set the timing is this correct? Thanks again amigos Quote
2STROKIN_IT Posted April 4, 2015 Author Report Posted April 4, 2015 Yeah it did and I set it at +4.. Thanks a lot I just wanted to verify that I did it correctly. Guess a little common sense does pay off! Quote
2STROKIN_IT Posted April 4, 2015 Author Report Posted April 4, 2015 Just pump.. Should I not be?? Quote
wayne_smith97 Posted April 4, 2015 Report Posted April 4, 2015 Did I miss where he said what fuel he is running and what compression he's at? If your running pump gas the +4 is good. If your on alky you can up it to 7 or 8 maybe more Quote
wayne_smith97 Posted April 6, 2015 Report Posted April 6, 2015 Im on pump fuel at +7° Good to know, I may try to push mine a little higher. Quote
trickedcarbine Posted April 6, 2015 Report Posted April 6, 2015 Im on pump fuel at +7°who did the domes, and what type of squish clearance, band width, chamber CC, and type of compression. There are quite a few pump motors with conservative domes that really wake up at 6-7 degrees and do it safely. 1 Quote
Pasi S. Posted April 6, 2015 Report Posted April 6, 2015 Every motor is a little different. In my opinion +4 is good and safe "starting point". I have read, that only few motors didn´t like anything over +2 or +3. I have basic bolt on´s with home made porting. I have custom cut domes, 9mm band, 20cc and 1.15mm squish. 155-160psi.With our "93" pump gas, I have been up to +8.5 on timing without any issues. However I didn´t feel any "gains" after +7.5. I felt a huge gain going from +5 to +7. Mostly I have been around +7 with T5´s and A&S Drag pipes. ..oh - and this is from sea level up to ~500ft above. Quote
2STROKIN_IT Posted April 7, 2015 Author Report Posted April 7, 2015 Yeah judging by all the input I may just leave as is till I rebuild. Last owner said it hadn't had the top end rebuilt in about 4 years. I'm almost sure that's not true, I'm gonna use the equation that every man should use when they ask a girl how many guys they have slept with.... Answer x 2= The truth!!!! Than I will mess with timing again, I'm gonna end up splitting the cases and giving it a once over than install 4 mil crank and all accommodations that go with it. Thanks again guys Quote
