i know how to tighten the chain and ive done it a lot and i know when its too loose the wquestion is how tight..how do you know..how many finger up from the swingarm till the chain wont go up any more......
thanks
shane
to adjust the chain to the correct tension is to throw a 8 or 10mm wrench into one of the sprocket teeth and tighten the chain down hard.
i dont really gage how tight to put mine i just get it tight enough so that it dosent fall off and enought slack so it dosent strech cuz when the shock is compressed the chain is pulled tighter hope that helped if you could tell what i was talking bout
hey thanks for all the info guys....now i know that i was in the right area range.,....ne ways shee roocki where did ya get your avatar??
