Hunter3473 Posted March 13, 2015 Report Posted March 13, 2015 Anyone know how to repair choke plunger that will not stay out? I took carbs off and there thoroughly cleaned inside and out but the choke plunger still will not stay out I have to hold the plunger out and kick. Not to big of a deal but would like it to work as it should. Is there a little retainer clip or something that holds the plunger in place when engaged? Quote
Hunter3473 Posted March 13, 2015 Author Report Posted March 13, 2015 Here is a pic of the carbs there the stock mik's Quote
wayne_smith97 Posted March 13, 2015 Report Posted March 13, 2015 Take a picture of the plunger. I she o ring there or is the clip wore Quote
Hunter3473 Posted March 13, 2015 Author Report Posted March 13, 2015 Is there supposed to be a clip or something on the grooves? Quote
Motooutcastxxx Posted March 13, 2015 Report Posted March 13, 2015 Just buy a new one.. http://www.farmandsandtoys.com/partdetail.asp?partid=394 Quote
BANSHEE HP Posted March 13, 2015 Report Posted March 13, 2015 Do not buy a new one... pull the plunger, hold it with needle nose pliers, take a small file and file the notch. Quote
Hunter3473 Posted March 13, 2015 Author Report Posted March 13, 2015 Which notch do I file? The ones underneath the spring or the bigger notch near the "handle" Quote
Hunter3473 Posted March 13, 2015 Author Report Posted March 13, 2015 A new one is 40$ if it's a free fix I'll try that first plus I really dont need the choke but would like everything to work as it should. Quote
BANSHEE HP Posted March 13, 2015 Report Posted March 13, 2015 There are 2 notches. When you fully extend the plunger you see them. Closer one to the knob is half choke, the further one is full choke Quote
BANSHEE HP Posted March 13, 2015 Report Posted March 13, 2015 You can pull the spring to one side, hold it with the needle nose and then file. Whatever is easier Quote
Motooutcastxxx Posted March 13, 2015 Report Posted March 13, 2015 Thought they were a little cheaper than that actually, I just hold the choke plunger out if I need it.. But I will certainly try this fix out myself at some point! Quote
Hunter3473 Posted March 13, 2015 Author Report Posted March 13, 2015 Trying to file it now I'll let you know how it goes Quote
BANSHEE HP Posted March 13, 2015 Report Posted March 13, 2015 You guys both owe me a dollar now. 1 Quote
