Joejr915 Posted February 10, 2015 Report Posted February 10, 2015 I put together a 465. It has k&t ported vitos cylinders on it. I am putting it alky from parts I had gathered from the years.I never had a motor on alky and need some help. It has 39 pwks pumper carbs. What should I set the timing at? what should the compression be for a alky motor? Are 39 pwks to small or should it have something have bigger carbs on it? Quote
possum Posted February 10, 2015 Report Posted February 10, 2015 start at +7, compression can be 150-200, 39s are fine Quote
Joejr915 Posted February 10, 2015 Author Report Posted February 10, 2015 No sure who set them up and can find out what the dumps and needle is in them this weekend Quote
RadarRacing Posted February 10, 2015 Report Posted February 10, 2015 Correct timing is dependant on squish, porting , and pipes. With small bore pipes you may be in the 8 to 10 range or even more , if you are running big bore pipes 6 to 7 should be a good place to start and probably not need more. Quote
Joejr915 Posted February 10, 2015 Author Report Posted February 10, 2015 Small bores shearers I have to check on the squish this weekend I think it's 45ish but not 100% thou. Quote
banshee332 Posted February 23, 2015 Report Posted February 23, 2015 Set timing at 10. Have tim cut you a set of domes. Crank the pjs all the way open and work your way down. Quote
RadarRacing Posted February 24, 2015 Report Posted February 24, 2015 Just like 332 said. I agree with him. 39mm pwks are just right and you dont need bigger. Quote
