2strokeBEAST Posted February 9, 2015 Report Posted February 9, 2015 Re building this motor. Started removing the clutch cover and can only get it separated about 1/2-3/4" from the case, its separating because the joint is sliding through the case.joint has not come out of the clutch cover at all, even after constant pulling. I tried using shims, lotta pressure, still wouldn't pull out. Sprayed some shyte in there too. WTF? Hacksaw? #15 in below http://fiche.worldofpowersports.com/wps/showmodel.asp?Type=18&make=yamahaatv&a=208&b=5&Action=O Quote
2strokeBEAST Posted February 9, 2015 Author Report Posted February 9, 2015 (edited) I took the clip off a while ago. Im wondering if the o ring in there has hardened. I figure I might have to just cut the joint apart and buy a new one. Edited February 9, 2015 by 2strokeBEAST Quote
2strokeBEAST Posted February 9, 2015 Author Report Posted February 9, 2015 Exactly, that clip just keeps it from pulling out of the case, not the cover. I took it off anyway. This things really pissin me off now. Quote
2strokeBEAST Posted February 9, 2015 Author Report Posted February 9, 2015 (edited) Ive been trying to post a pic. o well. I'll have to wait till next weekend to continue with this tear down anyway. Thanks for the help. I'll post some pics when I remove the F'n thing. Edited February 9, 2015 by 2strokeBEAST Quote
trickedcarbine Posted February 9, 2015 Report Posted February 9, 2015 Is the kick starter pulled off? Quote
willaduncan Posted February 9, 2015 Report Posted February 9, 2015 The heater tube binds very easy and there's probably quite a bit of build up on it, use some lube and twist it while pulling should slide out. If not then cut it out and buy a new one Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted February 9, 2015 Report Posted February 9, 2015 Put the cover on with just a bolt or two. Then pull the elbow toward the stator side as much as possible to take out the slack. Use a dead blow punch or wood block and a mallet to try and tap it free. Whatever you do, don't pry on the cover between it and the case. Quote
Zillaguy Posted February 10, 2015 Report Posted February 10, 2015 Twist the tube, and pull on the cover at the same time.. i always put import grey rtv on that oring.. it may be siliconed in place. Quote
