MessyJesse69 Posted February 6, 2015 Report Posted February 6, 2015 (edited) 01 banshee 10 hours on rebuild Rebuild consisted of New rings New crank seals New tranny Cylinders honed All new gaskets except for water pump Okay so here we go. Bike ran great for about 10 hours no issues. On my way home from a buddies I took the quick way home aka the road. I didn't stop or really slow down once the entire time. Ran at about 3/4 throttle. I get to my subdivision and let off the throttle (fuckin' neighbors). Bike acted like it got hit with an emp. It just died all of a sudden. It didn't shut off but it wouldn't make power. It would Rev up at idle but when I went to go the bike would just bog. Got it home and threw some new plugs in. I thought I fixed it with the change in how the bike ran but it's still bogging out when I hook up and the bike is trying to pill hard. Pulled the carbs and cleaned them. Pulled reeds and they appear to be fine. No chips and they are all flat with the rubber. What would cause the bike to be running fine all day and die on my way home? Maybe a clogged petcock? Blew air up into the tank and didn't see a big difference in fuel flow comming out of the tube. Switched plug caps around and nothing changed. I did happen to notice my carbs are slightly out of sync. Not hugely but still need some adjustment. Will but back in eyeball sync tonight. Right carb raises slightly before the left. The bike will start with the first kick and will sit there and idle. It lacks the throttle response I think it should habe off of idle. But still revs up. If this was your bike please give me the first couple things you would do if it was in your garage and causing you to lose sleep at night like ito causing me. What would cause it to die like that once I got off the throttle? It wouled Rev up in neutral but not in gear. To get it home I had to put it in 6th and give it no more than 1/4 throttle or it would bog. Edited February 6, 2015 by MessyJesse69 Quote
MessyJesse69 Posted February 6, 2015 Author Report Posted February 6, 2015 (edited) No tors. I'll check compression soon and attempt to build a leak down tester. Did not check compression when I rebuilt it Edited February 6, 2015 by MessyJesse69 Quote
MessyJesse69 Posted February 6, 2015 Author Report Posted February 6, 2015 As the bike sits it will pull hard until 3rd gear and then it dies. Quote
Larry's Shee Posted February 7, 2015 Report Posted February 7, 2015 Tank vent open? Pull petcock and clean properly. Dissasemble carbs and visually check jets are clean/open. Finish cleaning carbs, check float level. By chance you didn't happen to go thru water just before this started? Quote
MessyJesse69 Posted February 9, 2015 Author Report Posted February 9, 2015 I had been riding in the snow actually. I put the carbs back in sync and it seemed to clear up. Quote
MessyJesse69 Posted February 9, 2015 Author Report Posted February 9, 2015 My new problem is there is a hose that runs under the tank that has a splitter one end goes into the clutch cover and the other end is just dangling there with a white plastic thing on the end and I'm not sure where it goes. Can anyone help me? Quote
MessyJesse69 Posted February 9, 2015 Author Report Posted February 9, 2015 It looks like it's supposed to be put in somewhere. When I blow in it, it sounds like it's comming from the radiator. Quote
sheerider11 Posted February 9, 2015 Report Posted February 9, 2015 Back of case under motor mount. I'd suggest you put that back before you ride again Quote
MessyJesse69 Posted February 9, 2015 Author Report Posted February 9, 2015 Yeah I saw it and decided I was done for the day and THANK YOU VERY MUCH I'll get to ride tomorrow for the first time in like a month Quote
MessyJesse69 Posted February 9, 2015 Author Report Posted February 9, 2015 I still dont know how to check float level. I just put them back together the way they came off Quote
