DBR06Banshee10 Posted January 29, 2015 Report Posted January 29, 2015 Was wondering what bearings to use over stock replacement from yamaha? Any suggestions or ideas would help. Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted January 29, 2015 Report Posted January 29, 2015 Jeff at Fast now carries a complete transmission bearing kit. There is also the option of using a max load on the transmission output as well. Double up clips where possible or use full circle style replacements. 1 Quote
DBR06Banshee10 Posted January 29, 2015 Author Report Posted January 29, 2015 Jeff at Fast now carries a complete transmission bearing kit. There is also the option of using a max load on the transmission output as well. Double up clips where possible or use full circle style replacements. I have spoken to jeff at fast about it. I was just curious to if there was others out there because i seen hot rods made a kit for it Sent from my iPhone using Tapatalk Quote
Zillaguy Posted January 29, 2015 Report Posted January 29, 2015 You can always get the part numbers off the old bearings.. Then call a bearing house, like Motion Industries (Detroit Ball Bearing).. That way you choose any quality of bearing you want.. From Chinese cheapos, to the highest quality Swiss bearings.. Or anything in between.. Usually a bearing house is cheaper too, because they are wholesalers. Quote
trickedcarbine Posted January 30, 2015 Report Posted January 30, 2015 I have spoken to jeff at fast about it. I was just curious to if there was others out there because i seen hot rods made a kit for it Sent from my iPhone using Tapatalk Jeff's kit is the HotRods. Quote
DBR06Banshee10 Posted January 30, 2015 Author Report Posted January 30, 2015 You can always get the part numbers off the old bearings.. Then call a bearing house, like Motion Industries (Detroit Ball Bearing).. That way you choose any quality of bearing you want.. From Chinese cheapos, to the highest quality Swiss bearings.. Or anything in between.. Usually a bearing house is cheaper too, because they are wholesalers. I never heard of doing that before still sounds a little iffy Sent from my iPhone using Tapatalk Quote
DBR06Banshee10 Posted January 30, 2015 Author Report Posted January 30, 2015 Jeff's kit is the HotRods. Imma give jeff a call and see whats up i probably order crank from him too if I don't find a deal on a good used crank Sent from my iPhone using Tapatalk Quote
