When I took my engine apart from the previous owner there was only a gasket on the reed to cylinder side, the vitos gasket kit I got came with only 2 gaskets, but upon further research Ive seen some people say they use 4 total, adding some to the intake to reed side.
It passed a leak down test with only 2, but I wanted to know what the common practice was, I'll be making my own gasket from felpro 3157, oil/gas resistant material, the grey stuff, going to spray copper gasket on them too.
Yeah I'm using stock intakes, I figured the rubber would seal but f it I'll go back with 4.
I'm running VF4's, stock intakes, after rebuild I used 4 gaskets and still had leaks on both intakes, eventually had to use a little fuel safe gasket maker to seal. I hate using that shit but it's the only way I was able to get it sealed even with 4 gaskets
