Spiner Posted December 22, 2014 Report Posted December 22, 2014 When I put my banshee into first gear without giving it some gas , it stalls out no matter if it's warm or cold. Any ideas? Quote
sheerider11 Posted December 22, 2014 Report Posted December 22, 2014 Clutch adjustment. Try tightening up on the perch 1 Quote
Spiner Posted December 22, 2014 Author Report Posted December 22, 2014 I lined up the arrows , my clutch is adjuster perfectly. Quote
Surfrjag Posted December 22, 2014 Report Posted December 22, 2014 Maybe your clutch steels are warped or you basket has grooves... Sometimes it they sit the clutch will stick. Did you ride it much 1 Quote
Spiner Posted December 22, 2014 Author Report Posted December 22, 2014 I did about 15 Hours on it after I bought it. Quote
03DMshee Posted December 22, 2014 Report Posted December 22, 2014 I lined up the arrows , my clutch is adjuster perfectly. Just becuase those arrows are lined up doesnt mean its perfect.... 1 Quote
Spiner Posted December 22, 2014 Author Report Posted December 22, 2014 I can feel the clutch being lined up correctly , there is very minimal travel until clutch is begining to engage and vice versa. I read in the internet about 3 cables going into the clutch lever , I will check if I have them all. Topic : http://forums.everything2stroke.com/archive/index.php/t-19283.html Quote
sheerider11 Posted December 22, 2014 Report Posted December 22, 2014 FFS. Ask for help, goes to e2s and follows there advice. 1 Quote
Spiner Posted December 22, 2014 Author Report Posted December 22, 2014 I'm looking for ideas on how to fix it ;/. Do you guys have any other ideas? Quote
sheerider11 Posted December 22, 2014 Report Posted December 22, 2014 Stretched cable Warped plates Warped hub Warped pressure plate Groved basket Grooved hub Internal adjuster out of adjustment 1 Quote
Spiner Posted December 23, 2014 Author Report Posted December 23, 2014 I will have a look tomorrow when I come back from work Thanks guys ! Quote
possum Posted December 23, 2014 Report Posted December 23, 2014 clutch isnt disengaging apparently. see above post for possible causes. 1 Quote
Spiner Posted December 23, 2014 Author Report Posted December 23, 2014 Came late from work today so didn't have time to take a look at it , will update with feedback as soon as i get something going Thanks to all that helped ! Quote
