Miabansheeboys Posted December 20, 2014 Report Posted December 20, 2014 Is the dowel pin on the clutch cover really important? I forgot to put it in when i polished it any imput Quote
J-Madd Posted December 20, 2014 Report Posted December 20, 2014 No. It helps support the cover while kicking it, I think, but it'll be fine. Put it back next time. Quote
Man-O-Steele Posted December 20, 2014 Report Posted December 20, 2014 Its there for a reason.. why take the chance? Quote
sheerider11 Posted December 20, 2014 Report Posted December 20, 2014 Did you already put in the fluid and coolant? If not just put it in Quote
Miabansheeboys Posted December 20, 2014 Author Report Posted December 20, 2014 I guesss ill take it apart and re do itt Quote
Miabansheeboys Posted December 20, 2014 Author Report Posted December 20, 2014 I had put it all together started and all. When i was picking up i found itt i was like nooooooooo Quote
possum Posted December 20, 2014 Report Posted December 20, 2014 its just for alignment. no biggie Quote
trickedcarbine Posted December 20, 2014 Report Posted December 20, 2014 It'll help keep the water pump gear meshing well and keep the cover from mushing the O ring on the coolant tube. 1 Quote
Larry's Shee Posted December 20, 2014 Report Posted December 20, 2014 It'll help keep the water pump gear meshing well and keep the cover from mushing the O ring on the coolant tube. Best answer ^^^ Seldom are extra/uneeded parts designed Quote
sheerider11 Posted December 20, 2014 Report Posted December 20, 2014 Best answer ^^^ Seldom are extra/uneeded parts designedExplain that to the 5 gallon buckets of extra nuts and bolts I have. 1 Quote
