4 Drag Harnesses
4 Drag Harnesses priced to move! Top 2 are new harness for 97-06 and the
bottom 2 are modded, used OEM for 95-96. All drag harnesses have the bare
minimum needed to make your Banshee run: CDI•coil•killswitch•stator
**NOTE: 95-96 shortened harness has wiring for a coil & killswitch only**
Top Left- 97-06 JDS drag harness for the "under radiator" relocation
bracket - $50
Top Right- 97-06 OEM length drag harness - $55
Bottom Left- 95-96 JDS drag harness for the "under radiator" relocation
bracket - $35
Bottom Right- 95-96 shortened drag harness. CDI needs to be close enough
for the stator to directly plug in - $20
ALL PRICES INCLUDE FEES & SHIPPING
The 97-06 JDS harness has been covered with high temp PVC tubing. The OEM
drag harness has been covered with heat shrink. The 2 OEM modded harnesses
have been retaped.
Feel free to call,comment, or message with any questions.
Phone: 336-803-1602
PayPal email: lo95bowty@gmail.com
Sent from the Electric Chair
What's needed for the under radiator harness? Mounts etc
JDS Customs sells the bracket needed to relocate your CDI up front.....it uses the tank & radiator hardware to mount it, so the only hardware you would need is hardware to mount the CDI to the bracket.
