dailydrifter Posted November 30, 2014 Report Posted November 30, 2014 (edited) I have +2 arms so in the front id like to stay at standard width and in the back I have the stock axle so id like to go with a offset rim that gives me a bit more width to get closer to the width of the front. For the fronts im thinking 3+2 Offset 10 x 5 with a bolt pattern of 4 on 156 that is factory spec right? For the rears im not sure how offset works but i have the option of 8x8.5 3+5.5 Offset or 9x9 3+6 offset. Which rear rim would give me a wider stance? Edited November 30, 2014 by dailydrifter Quote
locogato11283 Posted November 30, 2014 Report Posted November 30, 2014 You will want 3/2 in the front and go with the 6/3 in the rear. You will be able to flip the rear rims/tires for the desired width. Quote
dailydrifter Posted November 30, 2014 Author Report Posted November 30, 2014 The rims im looking at buying have a reinforcement ring on the outside so if i flipped it they would look odd with the ring out on the fronts and the ring in on the rears. if I bought 6/3 offset for the rear would they still stick out a bit more then the factory rims with out having to flip them with the ring facing inwards? Quote
dailydrifter Posted November 30, 2014 Author Report Posted November 30, 2014 https://www.rockymountainatvmc.com/p/994/8641/ITP-Baja-Wheel?0&v=1442 Quote
locogato11283 Posted November 30, 2014 Report Posted November 30, 2014 OK, if you run those the way they are shown, they will be wider than OEM by a couple inches per side. The 3" offset will be towards the inside with the 6" offset on the outside. So if you want to be wider in the rear, you will be good with those. Quote
dailydrifter Posted November 30, 2014 Author Report Posted November 30, 2014 Awesome. Thanks for your input! Quote
