after finding that the banshee I got for a deal had a broken skirt on the right cylinder im in the process of rebuilding it now I already ordered a noss head 18cc domes and a Mattoon adj timing plate I was wondering how much safe timing I can put into this thing I was thinking +6 ill be running 110 at 750ft elevation and a guess at what my compression should be around and what pistons should I get its stock port and 1mm over so I was thinking vitos ss pistons or is that too much compression for those pistons and use wiesco I also have 30 pilots and 27.5 and have 320 mains or 300 you think that will be close to get me running safely any help would be appreciated and some how the hole intake side skirt came off and there was no damage to the head or bore I think the guy put it in there to sell it
I didn't know I was in school lol. I bought a banshee off craigslist I got a deal on it. only to find out the right piston was missing the intake side skirt so now im in the process of rebuilding it.
Already ordered
 noss head with 18cc domes
 matoon timing plate
I have to order pistons still either vitos ss or wiesco which ones are best for high compression. Im getting it bored to .60 over
The jugs are stock port and im at 750ft elevation who much compression do you think ill have and how much timing can I run. I will run 110 octane
Another question is if the head and crank looked good and only a little scratch from the ring. How did the whole intake side skirt not make any damage?
As for jets I have 320 mains and either 27.5 or 30 pilots should this be safe to fire it up.
Or should I have bigger mains
Thanks hopefully this punctuation helps a little
Edited by awblackmamba
