tyler73 Posted November 2, 2014 Report Posted November 2, 2014 my t5 pipe on the left is rubbing on cylinder and head and put a crack in the pipe how do i fix it so it don't rub Quote
special06shee Posted November 2, 2014 Report Posted November 2, 2014 You could shim the hangers, dent the pipe for clearance, or bent whole pipe. My old t5 were the same way, tight against the head. All i did was mount pipe w/o stinger tubes on, and pull(bend) the whole pipe outward until i had the clearance needed. Quote
tyler73 Posted November 2, 2014 Author Report Posted November 2, 2014 ok thanks yeah that was what i was thinking of doing after i eld up the hole and grind it smooth was to put a dent in that spot to have clearance Quote
