baxterl7333 Posted October 24, 2014 Report Posted October 24, 2014 Sent cases off to get trenched and just got them back. I didn't notice till I was assembling motor that they removed my seal for the clutch actuator. I know I can just buy a seal an put in the hole but can I buy a new bearing and put in hole if I already sealed the cases? Sent from my iPhone using Tapatalk Quote
baxterl7333 Posted October 25, 2014 Author Report Posted October 25, 2014 Ok thanks Sent from my iPhone using Tapatalk Quote
Abe Posted October 26, 2014 Report Posted October 26, 2014 If the bearing is good leave it be, very much a pain to remove that bearing even with the cases split Quote
sheerider11 Posted October 26, 2014 Report Posted October 26, 2014 If the bearing is good leave it be, very much a pain to remove that bearing even with the cases splitHell yeah it is. If you have access to one use this. Sent from my iPhone using Tapatalk Quote
sleeper06 Posted October 26, 2014 Report Posted October 26, 2014 That's the exact puller I have it's saved me many times Quote
trickedcarbine Posted October 27, 2014 Report Posted October 27, 2014 Good puller. You can usually just toss a clean piece of paper shop towel down under the bearing, then just implode the bearing. Do not reaf against the case in any way shape or form. Quote
baxterl7333 Posted October 27, 2014 Author Report Posted October 27, 2014 Pretty sure I just have to just drop bearing in place cause cases was cleaned and machine work was done on it and they removed everything from it Sent from my iPhone using Tapatalk Quote
