MessyJesse69 Posted October 22, 2014 Report Posted October 22, 2014 (edited) So when I had high rpms clutch worked when there was low rpms there was no clutch. I pulled the side cover off. When I tighten the adjuster bolt the part where the clutch cable connects to on the motor wont move. When I loosen it it moves freely no matter which way I turn it I can't get it to lign the piece on the motor up with that arrow. I really could use some help Edited October 22, 2014 by MessyJesse69 Quote
MessyJesse69 Posted October 22, 2014 Author Report Posted October 22, 2014 it wont let me upload photos but it looks as if there is just a nut on the adjuster bolt if you scroll down through here you see him put it on. it looks like there is a piece missing off mine or a bolt?? all i have on mine is a single nut??? Quote
MessyJesse69 Posted October 22, 2014 Author Report Posted October 22, 2014 http://s45.photobucket.com/user/Jesse_Crim/media/banshee/20141022_165146_zpsaa66a503.jpg.html http://s45.photobucket.com/user/Jesse_Crim/media/banshee/20141022_165324_zps0cdde246.jpg.html here are some pics i just wanna rip Quote
MessyJesse69 Posted October 22, 2014 Author Report Posted October 22, 2014 http://bansheehq.com/forums/index.php?showtopic=140912 heres where the guy puts his together. looks as if there is more parts on his than mine? ;( Quote
hoppedupandcutdown Posted October 23, 2014 Report Posted October 23, 2014 He has an aftermarket pancake bearing adjuster. You are missing a washer and a jam nut. ( at the very least) It will not hold adjustment like that. Quote
MessyJesse69 Posted October 23, 2014 Author Report Posted October 23, 2014 You were right I'm also missing the clamp that holds the bottom part of the clutch cable to the case. Thanks alot your help was muy bueno lol Quote
