PWK carbs are a little easier to work on than PJ carbs. I you are buying new I would go with PWK just because the idle is much easier to set and it is easy to figure out the jetting on them since most guys on here have a set on a bike or have ran a set on one of their bikes.
You think a slide and spring from regular pwk will fit an air striker?
I tried the one off my 39 pwk and looked like it closed all the way and would work fine, not 100 percent sure about it tho, you might be able to call keihn and ask.
No. The cutaway is different on air strikers.
Edit, it will fit and probably work. But your jetting will have to be adjusted.
  • Like 1
