sr73087 Posted October 3, 2014 Report Posted October 3, 2014 To add the several issues I have with the banshee I picked up for pretty cheap. I noticed this when buying it but thought it probably was not a huge deal since it does not look to truly support anything or is an area that would leak. I guess it just threw the chain at one point. Quote
sr73087 Posted October 3, 2014 Author Report Posted October 3, 2014 Does it have to be TIGd or can they use a MIG with a spool gun? Quote
sheerider11 Posted October 3, 2014 Report Posted October 3, 2014 You got lucky. I've seen more then a handful of motors lose all the trans fluid from that break. When I build a motor now I drill holes there. 1. for a drain 2. To give it a weak point to break an not put a tiny hole in the trans part of the case. Quote
sr73087 Posted October 3, 2014 Author Report Posted October 3, 2014 Is this something that is critical to do right away or can it wait? It looks like its basically only supporting part of the stator cover pretty much. Quote
banshee den Posted October 3, 2014 Report Posted October 3, 2014 (edited) if it not leaking oil don't worry about it at the moment. but defiantly get it fix RIGHT tho. then also buy case saver. Edited October 3, 2014 by banshee den Quote
bluebanshee98 Posted October 4, 2014 Report Posted October 4, 2014 ^ buy a cottonbranch racing case saver. Superior protection Quote
