satts Posted September 26, 2014 Report Posted September 26, 2014 Hi everyone i have a freshly built stock motor stock pipes too. Only mod is uni pod filters. Bike wont start without couple drops of gas on each filter then starts 1st kick .idles fine has very light bog jus off idle but is spitting alot of black oil out the left pipe and what looks to be gas out the right pipe. Motor isnt leaking held 8psi for 10 mins compression is 135 bogh cylinders jetting is 290 mains 25 pilot 2 turns on airscrew and needle middle clip carbs are in sync .so i think anyway .any help is appreciated Quote
sheerider11 Posted September 26, 2014 Report Posted September 26, 2014 Run the air screws in and see if that helps the start and bog. Did you use assembly lube or similar to assemble the motor? Quote
trickedcarbine Posted September 27, 2014 Report Posted September 27, 2014 Give it more pilot. 1 Quote
satts Posted September 28, 2014 Author Report Posted September 28, 2014 I used yamabond , I'm going to try a 27.5pilot, Quote
