Does anybody have a conversion chart for the Mikuni 042 hex jets, comparing jet number with inside diameter? From what I understand, these jets are not numbered according to inside diameter, but flow rate instead. My jets currently are drilled to .067" ID, would love to know what the corresponding jet number would be.
I asked a similar question before and would also like to know...that being said I did use pin gages to see the difference between jets. Ever size up you went, the hole got .001 bigger if I recall... (that was main jets)
Well Bennett they have them going up by 5's, Banshee mains go by 10's so in perspective of Banshee mains they go up .002" each size.
Not entirely true...The chart goes up by fives at first, and then by 10s. That being said I measured 320 330 and 340 mains, and regardless of what the chart says, they were .001 in size difference. I know for a fact you don't have precision pin gages laying around to check for yourself.
