Hey guys
Started having an issue with my fairly stock bike today, basically right plug is wet
Runs perfect for the first 30 seconds of riding then starts to miss/run on one cylinder, remove both plugs and right one is wet.
I have cleaned main jets/tested floats/checked for any air leaks/swapped leads/replaced plugs and inspected reeds for damage all with no change
Suggestions ?
Thanks
idk make sure your not loosing spark , or swap carbs to see if you get left plug to do it.  you already covered a lot ,mabey pull that pipe and have a look at piston. first id swap carbs. that's just me
Swap carbs. See what happens to check for carb prob. Swap plug wire sides to see if it switched the wet side. Since you checked reeds you then want to check piston condition, crank true etc.
Got it sorted now turns out a small part of where the little float bit seals had a lump stuck on it so would almost seal and just flood after a short ride
Thanks guys
