BakoBanshee Posted November 19, 2003 Report Share Posted November 19, 2003 where do you guys buy your compression testers from? I need to buy one but I don't know whether I could use a regular automotive one or I have to get one specifically for ATV engines. How much are they? Thanks Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted November 19, 2003 Report Share Posted November 19, 2003 get one that goes directly into your cylinder to get a acurate reading if you just wana check to make sure cylinders are even psi get any one they got to just check you want each side to be within 5 psi of each other about that Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted November 19, 2003 Report Share Posted November 19, 2003 get one that goes directly into your cylinder to get a acurate reading if you just wana check to make sure cylinders are even psi get any one they got to just check you want each side to be within 5 psi of each other about that Snap-on makes a nice one, 100 and change though Quote Link to comment Share on other sites More sharing options...
boonman Posted November 19, 2003 Report Share Posted November 19, 2003 I use a KAL Equipment. Thing is sweet, and the kit has every fitting you could ever need. It goes in without taking the tank off, and works perfectly. I got mine from Grainger, but I imagine it can be found elsewhere. www.grainger.com, part # 3T063. $112.24 I got mine on sale though.... Works splendidly!!! And the snap on one is a good guage too. My vacuum tester is a Kal as well. Quote Link to comment Share on other sites More sharing options...
