i run one... its very simple how it works... it allows the adjuster 2 spin inside the clutch pressure plate... the original has a hex end on it and is spun by the pressure plate... would i buy one again, probably not unless i was having problems with the ball weldin 2 the shaft... L8r d34
Very good investment. it will provide you with a piece of mind that you will never have a problem/nightmare of the ball welding to the shaft. Which is not a good thing. Whoever it has happened to I am sure will attest.....
