whobanshee
About whobanshee
  • Birthday 04/06/1975
Contact Methods
  • Website URL
    http://
  • ICQ
  • Yahoo
    Mr.grindstone
    vancouver,wa
  • Interests
    riding street and dunes,trails whereever
    2004, blue and white,fmf fattys and turbine core 2,twins k&n that is
whobanshee's Achievements
  1. FS custom 2 place atv rack black powdercoated steel, side load, built in hatch for toolbox access, ramps stored on side of rack 7' x 9' will fit any longbe full size p/u $1100.00 w 2,000 lbs removable winch $1000.00 w/o winch If interested I will email you pics
  2. nerfs are sold
  3. Have a set of ac propeg nerfs w/black nets only used 1 ride $150 obo
  4. no they dont have the heel guards but i will try to get a pic on here so you can see them,i will work on the pic in the am 9/18/04 sned me yor e mail address @ [email protected] and i will email you a pic
  5. I have a brand new set of ac racing pro peg nerfs w/ black nets (used 1 time only) for sale. $150.00 obo
  6. Have a real puzzle going here the right side exhaust is running hotter than the left and silencer is blueing, plugs look good, jetting is spot on,needle in stock location,so is air screw any ideas on whats up?I have 300 mains and 30 pilots running @ sea level bike seems to run great.
  7. retested mine today kind of a deep brown with the 30 looks ok to me
  8. well the needle jet did fall out of mine and to sickbanshee-990 no you do not have to remove the tors all the way just unscrew it off the top of the carbs and let it rest there and I removed my tank cuz I fiqured that while I was in there I would do a little extra clean up in those hard to reach places but you can rejet with out removing the tank if you want its up to you
  9. more brown than tan it looks oksy to me
  10. ok first thing I did was to remove the gas tank its simple remove the plastic and ther are 4 bolts 10mm in size and the fuel line at the bottom of the petcock.Once the tank is out of the way you have a clear shot to the carbs.Next you want to loosen the clamp that holds the tors on top of the carbs,then unscrew the tors from the carbs this will pull the slide and needle up with it(do one at a time to keep it simple).once you have the tors out of the way drain the carbs using the small phillips head screw at the bottem of the carbs it is towards the rear of the bike this wiill drain the bowls of the carbs. Once the carb is drained remove the drain line,the fuel supply line,and the choke hose that connects the two carbs together.Now loosen the clamp that holds the carb to the motor and pull the carb out of the boot,you should now have the carb in your hands, be careful whe you rotate the carb upside down because the needle jet will fall out just hold it in with your finger it is in the center of the carb so just reach in from on side or the other.Now take a phillips head screw driver and remove the four screws holding the bowl on there may be a small amount of gas left in the bowl so watch out.Once the bowl is removed you will see the main jet right in the middle it is holding a small white plastic piece in remove the main jet and piece of plastic there is a small tab on the plastic that goes into a post nect to the main jet inside that post is your pilot jet you will need a small flat bladed screw driver to reach it it is very small. remove pilot and insert new on and then replace the platic piece and in sert your new main to hold it in.now just put eveything back together in the reverse order that you removed it and reinstall carb and do the other side. you can do this without removing the carbs from the bike but its such a tight space I found it easier to just removes the carbs. if you live in oregon or washington i would be happy to help in person or over the phone let me know if this helps or if you need more info.good luck oh and one more thing make sure to line up your slides in the carbs or you will have the wide open and your shee will not start I speak from personnel experiance ha ha
  11. shawn at top dog racing said once the shee is jetted right adding new reeds should not affect it rechecked mine today and had a nice tan color on plugs after a 6th gear WOT coast to stop
  12. I use heave metal green just like a ball of cotton and they look new again les shwaub carries it as do most dealers
  13. never seen one of those??? let me know when you find out how it works
  14. youre right all shees like it a little different,but I do not have any dead spots and all i did was rejet the needle is still in factory position and so is the air screw and stock reed cages i do not know if changing the reed cages will call for you to rejet if you happen to live in the portland area give top dog racing a call and ask for shawn he was extremely helpful and answered all of my questions.I will be in there tommorrow picking up a few more goodies I will ask him about the reed cages and I will let you know at this post.by moving the clip down you are riching it up have you tried going up to lean it alittle? let me know
  15. i paid $ 4 bucks for 2 mains and 19 bucks for two pilots
