As you know I'm Having Electrical problems I'm not very sure which plug to connect it to.. The Harness only has Female ends but their the right Color. I have no spark with the Yellow and Red wire and black wire.
Solid green and red are from the primary. White with red stripe and white with green stripe are the trigger. These should be in a multi-pole connector going to the cdi. Yellow is stator a/c for lights etc. Black is the ground.
