tfaith08 Posted July 15, 2014 Report Posted July 15, 2014 It absolutely will. That's why a leak test actually matters. You'll end up with a 500 main (or larger) trying to get decent AFRs with an airleak, and it'll still run inconsistently as hell. Best option is to fix the leak, leak test again, go with a large jet and work down. I'd suggest a 400 and work down from there. 392 + pipes + aftermarket filter setup (I really hope) would put you above a 320. That's what I'm at with my T5s and open airbox. Quote
MustangK Posted July 15, 2014 Author Report Posted July 15, 2014 Dang that's what the company I ordered the Jets recommended and sent. 280 290 300 and 320. I hope the new cylinders aren't warped.. Quote
Bennett131 Posted July 16, 2014 Report Posted July 16, 2014 If it was run hot with an air leak depending on how long they probably are. Quote
MustangK Posted July 17, 2014 Author Report Posted July 17, 2014 Well it turns out I bought a banshee with a "new" big bore kit that aactually has a cracked cylinder. .. so I got fu**ed as usual. Quote
BUILDER Posted July 17, 2014 Report Posted July 17, 2014 I'd be trying 400s and working down. Sounds like you're ultra lean to me. LOL Do not put 400 mains in it that is way to damn big. Fix your air leak on your cylinder do a leak down test on it then fire it back up and see how it runs with everything back together right. Quote
MustangK Posted July 17, 2014 Author Report Posted July 17, 2014 Na the cylinder is cracked around 1 of the bolt holes.. Quote
MustangK Posted July 17, 2014 Author Report Posted July 17, 2014 Definitely can't afford a new cylinder. .. and since it's a big bore I'll have to have the same 392 bog bore or new pistons and rings... fml Quote
BUILDER Posted July 17, 2014 Report Posted July 17, 2014 Crack around one of the head stud holes? I would look for a set of good stock cylinders and pistons in the for sale section and just put it back to stock bore for now. Quote
tfaith08 Posted July 17, 2014 Report Posted July 17, 2014 LOL Do not put 400 mains in it that is way to damn big. Fix your air leak on your cylinder do a leak down test on it then fire it back up and see how it runs with everything back together right. For some reason I was thinking it was an aftermarket monoblock. Yeah, I doubt you'll ever touch a 400 main running gas if you just have the 68mm sleeves. Quote
dcalsv02 Posted July 18, 2014 Report Posted July 18, 2014 I have a set. unported, on first bore. switched them out for a set of other cylinders i had. pm me if you are interested. Quote
