jmeans83 Posted July 14, 2014 Report Posted July 14, 2014 Hey guys im brand new on bansheehq. Just got my first banshee a few days ago. Its a 1999 with full t5 pipes and k&n. When I test rode it, it ran great. So I bought it and took it home. decided to clean everything up. Cleaned the airfilter, powerwashed it and changed the tranny oil and drained the fuel. Previous owner was running yamalube 2s in it at around 28:1, I changed it to Klotz BeNol at 32:1. ever since I did this it has started running bad on that one cylinder, Not smoking as much as the right cylinder and backfiring. I then proceeded to take the carbs off and clean them up. found out im running 240 mains, which I think is to lean. But that still doesn't tell me why one cylinder is running bad. Thanks guys Quote
984mmshee Posted July 14, 2014 Report Posted July 14, 2014 Check all electrical connections and clean grounds . Also pull stator cover and make sure pickup gap is correct and the nubs on flywheel are clean and not rusty. Quote
jmeans83 Posted July 14, 2014 Author Report Posted July 14, 2014 how do I check the pickup gap? Quote
jmeans83 Posted July 14, 2014 Author Report Posted July 14, 2014 couldn't I just switch the spark plug caps and see if it does it on the right cylinder if its an electrical problem? Quote
jmeans83 Posted July 14, 2014 Author Report Posted July 14, 2014 alright, thank you. ill let you know what happens after work Quote
Banman1122 Posted July 24, 2014 Report Posted July 24, 2014 Sounds like it's blown up. Sent from my iPhone using Tapatalk Quote
