Skitso559 Posted June 30, 2014 Report Posted June 30, 2014 So the days are counting down and im getting even closer to getting my banshee, i was suppose to get one today but I cant pay 3000 for intrest so im going to buy off craigslist, just incase I might run into any problems I just want to know now, how much does it take to do a full motor rebuild? And also how much sepretly (top end, bottem end) thats all I got for now any help appreciated! Quote
Larry's Shee Posted June 30, 2014 Report Posted June 30, 2014 Time for you to do your own math and research Quote
Bennett131 Posted June 30, 2014 Report Posted June 30, 2014 A full motor build? That could have about 100 different answers... Quote
Deadbeat Posted June 30, 2014 Report Posted June 30, 2014 check out F.A.S.T`s site for some ballpark figures on parts / kits / services Quote
Skitso559 Posted June 30, 2014 Author Report Posted June 30, 2014 check out F.A.S.T`s site for some ballpark figures on parts / kits / services Thanks deadbeat I sure will! Quote
sprinklerman Posted June 30, 2014 Report Posted June 30, 2014 I'd allow 3000.00 for a quality build..As long as you are going to stay in the 4mm range 1 Quote
sheerider11 Posted June 30, 2014 Report Posted June 30, 2014 I'd allow 3000.00 for a quality build..As long as you are going to stay in the 4mm rangeSounds about right. This will replace everything needing attention and give you cushion for unseen expenses. Quote
salmon_slayer06 Posted June 30, 2014 Report Posted June 30, 2014 4 mill crank, port cyl., 93 octane rated head, some pwk carbs, t5 pipes, boyesen reeds or the Vforce ones, adjustable timing plate, some trans mods that can be done on own if you have access to bridgeport.... I bought my reaming cutters or reaming bits off Ebay and didn't cost me much but have a machinist cut the dogs on the gears look on forum for threads on this, rebuild the clutch. Might like a +2 front end, replace the sprockets and chain, get some new slides, replace the axle bearings, swingarm bearings, rear linkage bearings, put new front hub bearings in, and last but not least I'd get some new shocks the stage 3 elkas are on sale but the Race tech GS3's are better cause you get the hi and low speed dampening on the fronts and get rebound adjust also. The elkas are hi speed compression dampening no rebound adjustment but are still 10x better than stock...... I'd say this is in the 3k-4k range. And this will be a run of the mill banshees on any dune but will be a blast to ride. Good trail set up. Quote
Skitso559 Posted July 1, 2014 Author Report Posted July 1, 2014 Well igot 1g saved up the quad im lookig at is 02 for 1900 but it has pipes and all that basic stuff, im just thinking more of the what if possibilities of the quad but after I buy it which will be very soon ill let you guys no if anything goes wrong with it hopefully you badasses will be able to identify the problem and save me 50 bucks for just a check up because a 02 quad for 1900 in this area is a little iffy Quote
Skitso559 Posted July 1, 2014 Author Report Posted July 1, 2014 http://visalia.craigslist.org/mcy/4525851183.html oh and this is the final pick guys! Quote
salmon_slayer06 Posted July 1, 2014 Report Posted July 1, 2014 If it runs and the frame isn't bent I'd say go for it. Quote
Bennett131 Posted July 1, 2014 Report Posted July 1, 2014 As long as nobody else scoops it up in the mean time lol Quote
Skitso559 Posted July 1, 2014 Author Report Posted July 1, 2014 As long as nobody else scoops it up in the mean time lol yeah I know man its happend twice already but if its been up for a month and havnt sold im sure two more weeks wont hurt! Quote
Skitso559 Posted July 1, 2014 Author Report Posted July 1, 2014 If it runs and the frame isn't bent I'd say go for it. Good way to tell if frames bent? Quote
