When i was rebuilding my yz125 i had to replace some bearings, but instead of ordering 2 bearings for like 30 bucks from the stealership, you can find the measurements to them and order like 10 for $20 from amazon, is there some kind of list like that on this forum ? If not ill take note of the bearings when i pull them out from various places
Literally just put together a motor on Sunday for a buddy. The Closest thing will be a full set from HotRods. It's trans bearings, trans shift drum bearing, and output collar for the sprocket side. The crank stuff, just order two MAX LOAD Bearings. It ain't gonna be no $20 bucks though. All the Hot Rods kit is pretty nice and fast has it for $100. Max loads are $30 ea. you can also use a fresh max load on the trans out put shaft.
