m671054 Posted June 10, 2014 Report Posted June 10, 2014 Whos manifolds? There was a post on here from chariot with alot of info on boots that fit certain carbs and mounting bolt spreads Quote
Timshee Posted June 10, 2014 Author Report Posted June 10, 2014 I believe there chariot manifolds Quote
m671054 Posted June 11, 2014 Report Posted June 11, 2014 Use the search function. Its all on here with part numbers Quote
m671054 Posted June 12, 2014 Report Posted June 12, 2014 Once you locate the thread i mentioned you can order from anywhere. They are cheaper once you figure out the part# you need. Quote
