Power_Man Posted June 2, 2014 Report Posted June 2, 2014 We bought two Tors eliminator kits for identical banshee's. First one we did was my quad. Worked like a charm. Runs good idles fine. DONE Second kit went on friends. installation went smoother than mine. Fire it up and right side cylinder is missing. you can see the right exhaust will stop blowing smoke every now and It also bogs when trying to rev it up. We have pulled the carbs off and re cleaned, inspected. Triple checked everything. We didn't change jets or anything. simply just removed TORS. We swapped plug boots. Problem stayed on right cylinder. anyone else have similar problem? Quote
Power_Man Posted June 2, 2014 Author Report Posted June 2, 2014 Tried to edit my first post, but i should of said plus are almost dripping wet. Quote
Sandking Posted June 2, 2014 Report Posted June 2, 2014 Check the right side rubber manifold under the metal band if torn you have an air leak Sent from my SCH-I535 using Tapatalk Quote
Power_Man Posted June 2, 2014 Author Report Posted June 2, 2014 Did you sync the carbs afterwards Yes sir. Check the right side rubber manifold under the metal band if torn you have an air leak Sent from my SCH-I535 using Tapatalk Will check when i get home and report back. Quote
four2err0r Posted June 2, 2014 Report Posted June 2, 2014 My TORS eliminator came with two new caps, so how would switching be attributed to this? Unless I'm misunderstanding what you're saying. Sent from my SAMSUNG-SGH-I337 using Tapatalk Quote
Power_Man Posted June 2, 2014 Author Report Posted June 2, 2014 My TORS eliminator came with two new caps, so how would switching be attributed to this? Unless I'm misunderstanding what you're saying. Sent from my SAMSUNG-SGH-I337 using Tapatalk Yes, he has me confused as well. Come with new tops and cables. The only thing that stays the same are slides and carbs. Quote
hp2000 Posted June 2, 2014 Report Posted June 2, 2014 Student4life probably meant carb slides and not carb tops. You can't have the slides in the wrong carb or the wrong bowl those 2 parts are specific to each carb. Sent from my iPhone using Tapatalk Quote
Power_Man Posted June 2, 2014 Author Report Posted June 2, 2014 How do you tell which slide goes in which carb? Quote
BUILDER Posted June 3, 2014 Report Posted June 3, 2014 The half moon cut out faces the rear of the carb if they are in wrong it will run like shit Quote
registered user Posted June 3, 2014 Report Posted June 3, 2014 toomey site says you suppose to leave the crossover tube on. just sayin Quote
Joeladm Posted June 3, 2014 Report Posted June 3, 2014 The slide for the left carb has a slot cut on the top on the front and back side. Quote
Joeladm Posted June 3, 2014 Report Posted June 3, 2014 here is a pic of the slide that goes in the left side Quote
