Mr1Hundred Posted June 1, 2014 Report Posted June 1, 2014 Hello all, usually i just troll the forums looking for information but this time im really stuck, so i decided to make an account The problems started after i transferred everything that was on a bent frame to a new frame that i bought (which is straight), at first it wouldnt start, i knew it was electrical so tested everything (it was all in range) and it turned out to be a problem with the ground, fine, it starts now but it runs so bad, (it didnt run like this before), it smokes hard and doesnt rev, i attached a link the tors are removed, i also took off the parking brake cable (does this change anything?), the carbs are synced, i cleaned the carbs, i took the reeds off to inspect them, i put new fuel in, it has alot of spark, im not sure what the problem is also it dies when i let the throttle off competely, im guess that is just the idle screws ? Quote
hoppedupandcutdown Posted June 1, 2014 Report Posted June 1, 2014 did you do anything with the wiring from the park brake switch? Back at the CDI find the green/yellow stripe wire, cut it and tape it off. Quote
Mr1Hundred Posted June 1, 2014 Author Report Posted June 1, 2014 no i didnt do anything with the wiring from the parking brake, do you think that is what it is ? according to this diagram there is go Green/Yellow wire http://www.dfn.com/agservices/elecfaq.html Quote
Mr1Hundred Posted June 1, 2014 Author Report Posted June 1, 2014 i meant there is no** green and yellow wire Quote
hoppedupandcutdown Posted June 1, 2014 Report Posted June 1, 2014 You're killing me, Benjamin. That's an early diagram. Go look under the seat on your banshee at the CDI. Quote
Starwriter Posted June 1, 2014 Report Posted June 1, 2014 I bet the carb slides are swapped. When you have them swapped, the slide cutaway ends up towards the motor. The cutaway should be towards the air filter. Quote
Mr1Hundred Posted June 1, 2014 Author Report Posted June 1, 2014 It was the wire, i disconnected the sensor from the parking brake, thank you so much guys, think rips so hard, i had the biggest smile on my face and was laughing while i ripped around, forgot how much fun it is Quote
hoppedupandcutdown Posted June 1, 2014 Report Posted June 1, 2014 That's cuz Banshee's are awsome...welcome to BHQ Quote
