Ok I no this page is full of knowledge and need some help. I just restored a banshee with a 10mil Cheetah in it. I removed the PV and had the motor gone through by a local shop. On the second time out it began to run like crap, so I took it back to the shop. They tore into it and discovered the one of my reeds (VForce 2) had a broken pedal. With further review they discovered that one of the screws (typical) came loose from the reed and took out my piston and dome. Where is where I need advice... It has 125mm rods, 72.5 pistons with 18mm wrist pins. I have been told that pistons with 18mm wrist pins are obsolete and only a couple left in existence and cost $350-400.00 a pair. Is that true? Does anyone know of a vendor that I can find these?
Thanks in advance.
The bike is still at the shop, I should have it back in a few days so I can get the number off the piston then. I haven't called anyone yet, just thought I would ask around in the meantime.
