jdubplat Posted May 13, 2014 Report Posted May 13, 2014 I need some input on my banshee. Haven't got started to dig in deep yet. Ok, I was riding my banshee the other day and it ran fine for about a 1/4 mile until I had to scoot across a road. As soon as I hit the throttle quick to skip across the road it kind of bogged but would still run. I turned around to go home and it wasn't trying to go unless I revved it high. I figured I would just push it the rest of the way home. I got it home and kicked it over and it started right up. I did a compression test and it was 110-115 in the right cylinder and 115 in the left. When it was idling it looked like the right pipe wasn't flowing as fast as it should. I know it could be a number of things. Just wanted some input on where to start. Don't have much time to sit and look at it day in and day out seeing I have 3 kids and my knowledge for the Banshee isn't the greatest. The right plug looked a little dry as the left one looked a little damp. Before this happened It wouldn't idle until it got warmed up. Quote
WINDYCITYJOHN400 Posted May 13, 2014 Report Posted May 13, 2014 Fouled plug Clogged jets Start there. Quote
m671054 Posted May 13, 2014 Report Posted May 13, 2014 Jet fell out into bowl or choke tube dried out and came loose Quote
Larry's Shee Posted May 13, 2014 Report Posted May 13, 2014 Set float levels while fucking with it. Quote
Glenyboy Posted May 13, 2014 Report Posted May 13, 2014 Toss carbs in scrap and buy a zillafuck EFI system I heard driftingbanshee's kit was better and cheaper? Quote
jdubplat Posted May 18, 2014 Author Report Posted May 18, 2014 Turned out the plug was done for and I wasn't getting a spark. Replaced both plugs and its back to prrrring like a kitten. Thanks guys for your input. I appreciate it. Quote
