gareth2689 Posted May 6, 2014 Report Posted May 6, 2014 Hi, I am in the middle of rebuilding my top end and replacing the crank seals as one of them is leaking air. Since I have the cases split in half I wanted to replace the following seals Crank seals Seal behind front sprocket Shift lever seal Clutch push lever seal Kick start seal Are these all included in the tusk engine seal kit? Or should I buy them separately from the dealers? Has anybody used this kit, is it any good? Also is there any other seals I should replace. This is my first time splitting the cases since I have owned the shee. Thanks Sent from my iPhone using Tapatalk Quote
2004LEBanshee Posted May 6, 2014 Report Posted May 6, 2014 Always had great luck with a k&s seal kit. Sponsors and ebay sell them. There a little more then tusk though. About $40 for every seal in the engine. Worth it Quote
gareth2689 Posted May 7, 2014 Author Report Posted May 7, 2014 Thanks for the replies. I have seen the k&s seal kit so I will probably go with it. Does it include all the seals I mentioned above? Sent from my iPhone using Tapatalk Quote
2004LEBanshee Posted May 7, 2014 Report Posted May 7, 2014 Every seal on the motor and side case. There is no other seal you need. There all labeled. Great kit. Quote
