lsiers616 Posted May 5, 2014 Report Posted May 5, 2014 hav a 2001 banshee i havnt messed with n a couple years ive been trying to get it tuned up to ride some this year but it spits n sputters if u cram the fuel to it if u gradually give it the gas it runs decent up to bout half throttle and its not hardly smoking at all like it should i checked the plugs they look like its burning about perfect light brown color any help would be appreciated Quote
WINDYCITYJOHN400 Posted May 5, 2014 Report Posted May 5, 2014 Clean the carbs. Remove jets and clean with brake cleaner. Check float levels Inspect choke tube. If that get's done and you still have issues....delete TORS and do a leak check. Quote
lsiers616 Posted May 5, 2014 Author Report Posted May 5, 2014 I drained the gas before i stated on it n put fresh in it the tors is deleted and i cleaned the carbs its got rad valves in it i had a cracked reed so put new ones in it but i think they give me just regular pro series reeds they looked different and had 260 jets in it i went down to a 240 jet and like i said the spark plugs look good it has paul turner high rev pipes, its ported, k&n air filter with open box Quote
lsiers616 Posted May 5, 2014 Author Report Posted May 5, 2014 I hav not checked the choke tube but i will because im gonna replace it with a choke tube off of an old carb because the choke tube on it now u have to hold it out thank you all. Quote
BrokeVW Posted May 5, 2014 Report Posted May 5, 2014 (edited) I hav not checked the choke tube but i will because im gonna replace it with a choke tube off of an old carb because the choke tube on it now u have to hold it out thank you all. I thought he meant the choke connector between the 2 carbs, not the actual choke plunger. If the choke plunger is not staying pulled out, the spring is pulling it shut again because the small clip that fits into the grooves on the shaft is no longer fitting the grooves and failing to act as a detent to hold the choke open against the spring pressure. The link isn't working right, it should jump immediately to the 2:48 mark in the video so start the video then jump to 2:48 to see the choke spring and detent explanation.... Edited May 5, 2014 by BrokeVW Quote
lsiers616 Posted May 5, 2014 Author Report Posted May 5, 2014 The hose running between the 2 carbs is good i checked it Quote
03DMshee Posted May 5, 2014 Report Posted May 5, 2014 Id get them 240's out of there immediately. ..id go back up to 280 and start there... Quote
lsiers616 Posted May 5, 2014 Author Report Posted May 5, 2014 Thats kinda what i thought but i wasnt sure i will try that soon as i get time Quote
lsiers616 Posted May 12, 2014 Author Report Posted May 12, 2014 I havnt had time to mess with it yet ive been super busy im going to try to get to it this week Quote
Jereme6655 Posted May 14, 2014 Report Posted May 14, 2014 depending on the pipe, elevation, and temp combo.....you'd be looking more like a 280-290s area. If it really is ported.....well then you're gonna need more on top of that. Not to mention that when running aftermarket pipes, most require a 27.5 pilot jet to keep it running correctly on the low end of the rev range. hell Im running a dune/play port from jeff at FAST with fmf fatties, pod filters, and 20cc domes and im running, 27.5 pilots and 340 main jets. Quote
MarineNYC Posted May 14, 2014 Report Posted May 14, 2014 On unported motor I was running 310 mains 30 pilot @ sea level. Think you need to bump those jets up Quote
