BrokeVW
About BrokeVW
  • Birthday 11/26/1973
    Columbus, OH
  • Interests
    I like money.
    Deep Purplish Blue 2000 Banshee, Pro Circuit Platinum/Type 296 exhaust, V-Force3 Reeds, Pro Design Intake, Case Saver, #320 Main, #27.5 Pilot, original bore and stroke
BrokeVW's Achievements
  1. German SKF brand crank bearings arrived, thanks much! Brian
  2. Payment sent for the TZ bearings, thanks! Brian
  3. I'll take them. PM the paypal address to send the $50 to and payment will be made tonight. Brian
  4. How much does the motor weigh, and what ZIP code is it in (92227)? I would have to have it shipped to Ohio, can you crate it to securely make the trip via UPS Ground? Is there anything wrong with it? Any leaks? (carbs, casing, etc.) When was it built? Any casing damage inside or from chain? Engine, reeds, carbs, and pipes for $1500? I'm a serious buyer with money in hand, if we can strike a deal... email me at [email protected] to discuss specifics. Brian
  5. Per Evan at RaceTech who sold me the stator and rectifier/regulator when I asked him: "Yes you can definitely use the chassis as a ground for the DC system, or you can run return wires to each light and back to the negative terminal, either way is fine." Per TrailTech .PDF instructions http://gallery.trailtech.net/media/instructions/lights/regrec/010-ELV-71.pdf "Do not connect to frame ground." I'm really not sure why there is so much conflicting info about this.
  6. I have the RaceTech 200W stator and the regulator/rectifier they include with the stator. This is the kit http://racetechelectric.com/i-10388144-95-06-yamaha-banshee-high-power-200w-dc-stator-regulator-rectifier-kit.html Right now I have the stock regulator removed, I have the 2 bullet connector wires from the stator (yellow and white) unplugged from the bullet connectors in the stock harness (yellow and black), and the stock chassis ground wire is not connected (it uses one of the bolts that mount the stock regulator). I checked for continuity between the black bullet connector and the chassis ground wire, and they have continuity. I checked from the chassis ground to the black wire that is at the key switch plug in front of the fuel tank, that plug has continuity with the black bullet terminal and the chassis ground terminal. The key switch black wire does NOT have continuity with the chassis at this point, as the chassis ground is removed and hanging in the air under the seat. The key still works and the bike still starts, runs, and turns off with the key... which I don't fully understand because I thought it needed the black wire to connect to the chassis to work. Apparently the ignition side of things does not need a chassis ground and I'm not sure why. The only wires I have coming out of the stator that are being used are the 4 wires found in the white plastic connector. It looks like I'll need to run dedicated DC ground wires all over then for the lighting and so on, thanks for the info.
  7. I had not thought about using a 12V AC relay, I was thinking only of the typical Bosch style 12V DC relays I usually use. I had not planned to do so, the stock regulator is only regulating the yellow wire that feeds the stock headlights. Since I was converting to DC, I removed the stock regulator as I didn't think it would be needed for anything, but I can see that if I decide to use an AC relay I would need the AC regulated to 12V to protect the relay.
  8. Can the chassis be used as ground for both the AC and DC circuits? I've read the thread with the magazine article posted about DC conversions, and I've been over the Clymer and BansheeHQ Electrical FAQ info several times, and I think I almost have it straight in my head. Please correct me if any of the below is wrong.... --The stock stator is AC only, both on the lighting and ignition circuits. --The lights operate on AC but LEDs or HIDs will not because the regular bulb filament doesn't care which direction the current passes through it or if it switches from + to - and back again, as long as it is passing current it will glow. --The lighting circuit has the voltage regulated to about 12V max to prevent the bulbs blowing. --The AC ground is on the chassis, using one of the bolts for the voltage regulator. If I have installed an aftermarket 200W DC stator and the regulator/rectifier that comes with the stator, I now have a DC circuit with a dedicated DC hot and ground. Can I run that DC ground to the chassis while leaving the stock ground for the AC ignition in place on the chassis as well? I want to use the stock headlight switch to operate new LED lights. I plan to use a relay, the headlight switch will send 12V to the relay, the relay will connect the battery to the lights. If I can use the chassis for both AC and DC ground, I can use the stock light switch wires to operate the relay if I only feed it DC+ into the yellow, after disconnecting it from the old stock AC wire. Thanks!
  9. 50% of the badassery of a Banshee originates from the dual pipe look. I would never change that. The other 50% of the badassery would be the sound. I'd be afraid of altering that with a 2-to-1 exhaust.
  10. Our fuel is $4/gal now and heading up.... soon you'll all be able to ride blistering-fast Banshees and have them all chromed and gold plated.
  11. Those silly fuckers thinking the Banshee is an All Terrain Vehicle! Why, those fucking fools! What ever gave them that idea anyway? The knobby tires? Did they think the seals and gaskets and rubber boots are there to protect from dirt, dust and mud? What a bunch of fucking retards! Those are all clearly for looks, and serve no REAL purpose. Everybody knows they should be ran without fenders and air boxes, errrrr'body. It's like some people think they should ride them in the rain or mud or something. Anyone will tell you they aren't any good at anything but straight line runs, they require rebuilding every 38 minutes of run time, they blow up 100% of the time if you take them in the mud, and pockets on shirts are for faggots. Yep.
  12. Get out more then. They're handy. My airbox drain plug thing is always put in my front shirt pocket when washing the Banshee. I never remember to remove it before hand, so I notice it with the hose in my hand and pop it off and into my pocket so the box can drain. Without a pocket, I'll lose the plug, dirt and mud will get in, my engine will be fucked, and all because YOU fail to realize the importance of a front shirt pocket. Thanks, thanks a fucking lot.
  13. OK, yeah, but just to be clear, it DOES have a pocket? I'm also for a Banshee image... they fucking look good. Without the ability to put the SOUND of the Banshee on a shirt, the next best thing is an image of one, in my not so fucking humble opinion.
  14. Smokers, duh. I only wear shirts with pockets because shirts don't have tags now, they have printed-on tags which fade in no time. I fucking hate putting my shirt on backwards, and I don't feel like hunting for a faded logo. Finding the pocket is easy when you grab the shirt out of the closet, that side faces front. Done. Plus, my smokes fit in that pocket, as previously mentioned.
  15. It's the first result in Google when you search for 'Banshee VIN decoder' and it had pics and decoded the VIN on the same page so I posted it... the guy didn't ask where to buy stuff, he asked how to tell what year Banshee he had. I didn't even notice there was stuff for sale there, it just had the info the OP was looking for.
