samici Posted April 13, 2014 Report Posted April 13, 2014 So I finally got my Shee runnin good after weather change got it into 5th and it just stalled out after lookin around my idle screw shook pretty far out fouled plug put new plugs in let it dry out a bit put it back NO SPARK put the plug to the block to check em nothin went to coil with voltmeter useing ohms part the plug wires were good but the boots weren't reading any resistance so I ordered new boots while waiting for parts after this is where I'm lost not sure how EXACTLY to check coil or black and orange wire into coil the resistance on the terminals of coil where black n orange plug in so when I put the tester on blk wire and block it reads but not when I have tester to orange wire an block not sure if I'm testing it right or if troubleshooting the wrong thing please any help would be appreciated Quote
samici Posted April 13, 2014 Author Report Posted April 13, 2014 There is resistance on the terminals of coil where blk n orange plug in **** is what I ment Quote
samici Posted April 13, 2014 Author Report Posted April 13, 2014 Took stator cover off too and those wires were at 150k ohm check ignition wires they're good so my problem is deffinatly between cdi and coil I think :/ Quote
uman1030 Posted April 13, 2014 Report Posted April 13, 2014 http://www.dfn.com/agservices/elecfaq.html should help you with testing the electrical system. Unplug the Tors brain to rule that out as a cause if it is still connected. Quote
samici Posted April 13, 2014 Author Report Posted April 13, 2014 Sorry shoulda said something tors is already off completely. i just assume people don't leave them on Quote
samici Posted April 13, 2014 Author Report Posted April 13, 2014 So I'm thinkin I'll just wait for the new boots to come in see if I have spark and go from there if not spark I'll swap a buddys cdi to see if that's another issue thanks for the link and reply I've seen this before but like an ass I just skimmed through let ya know when I figured it out its too nice for her to be sitting around now Quote
Larry's Shee Posted April 14, 2014 Report Posted April 14, 2014 Never assume anything. Pull flwheel, clean any rust off stator poles and timing nubs. IF everything ohms out, check all connections are clean and tight (might as well add dielectric grease). Check all grounds, consider running a ground wire from coil back to engine. Trim 1/4" from plug wires. Be sure to set pick coil gap at both nubs. Please post results. Quote
samici Posted April 15, 2014 Author Report Posted April 15, 2014 So i put the new coil on still no spark but my boots have resistance now (it was cheaper for me to order new coil set up then just boots) so anyway I traced back further and it's deffinatly between the stator wires by the cdi to the stator itself. when I pulled connector off by cdi and tried testing the leads while someone kicked it there was nothing which means it's shop time for me stator n shit is outta my league for this beginner but I learned a lot from this site and you guys thanks for all the information I'll keep ya updated what a shop tells me just didn't wanna take it to em say idk what's wrong and have em charge me out the ass for all kinds of dumb shit Quote
samici Posted April 15, 2014 Author Report Posted April 15, 2014 If i had more time i wouldn't mind doin it myself and learning more but it getting nice out and now i just want to ride. Cop out i know but I'm serious Quote
wayne_smith97 Posted April 15, 2014 Report Posted April 15, 2014 Stator is super easy to replace Quote
Larry's Shee Posted April 15, 2014 Report Posted April 15, 2014 It will take longer to get it to a "shop" than to replace a stator. Plus you'll wait a week or two for the job to get done. $20 for a flywheel puller. Quote
samici Posted April 15, 2014 Author Report Posted April 15, 2014 Yeah i seen on YouTube not that bad once i get everything apart and back, i have a few questions though. Like how exactly do i set my gap just push down the coil till its at the proper height? Cause the mount doesn't allow any movement so it not like I can loosen the bolts and then move it n tighten it back up. I don't have it apart yet still have to get puller and somthing to hold fly wheel but if one of you guys can give some advice I'd appreciate it just the cover is off for now. Maybe let me know some other things to look for like a sheared key etc etc.. or maybe how or what to test in more detail like I can get the specs of what it should be but not exact sure how to test it i just told residential electrical in votech so I have some knowledge of how to test resistance and get the concept of hoe the stator n flywheel work Quote
samici Posted April 15, 2014 Author Report Posted April 15, 2014 Shit now that i look at the gap between the nub and coil prong is like 1/8th of an inch maybe exaggerated but it's way more then one or 2 business cards seems like a good starting point right? Quote
samici Posted April 15, 2014 Author Report Posted April 15, 2014 It was at 5 cards just for arguments sake and fyi seems to be a better starting point then new stator so how exactly do i adjust this thing lol? Quote
samici Posted April 15, 2014 Author Report Posted April 15, 2014 I also noticed that they have and adjustable timing plate at +5 im assuming because they put a notch next to plate and the notch is at +5..I'm the 3rd owner of the bike so I'm told and and 2nd owner couldn't tell me much about it i was just worried about compression n leaks at the time of purchase which both were good plus I got it for kind of a steal Quote
