I got my -2 swingarm on but now my silencers touch the ground instead of my grab bar. I am wondering if the PRM Baja or deser grab bars come back enough to help me with this problem. All i need is a grab bar that is about 2 inches farther back then stock.
thanks
pipes are fmf sst's with the core 2's
I got the dg beer rack and fmf pipe setup. My silencers are a WAYS from the ground. I'm sure the PRM would fix it though.
Fro, The shortened swingarm makes it to were your grab bar hits at a different angle( more towards the underside) so I see were the silencers would scrape w/a stock grab bar.
Mike
um -2 swing arm dousn't have anything to do with silincers or a grab bar nothing should have changed can you explain when your silincers touch the ground  :blink:
because when you tilt your shee on its azz the grab bar and the back wheels are what is actually holding it. If you shorten the swing arm 2 inches then it is putting the rear end at a greater angle and therefore the silencers are exposed to damage because the grab bar cannot do its job any more.
Don't put it on its grab bar......W/ the -2, wheelies are easy as hell and don't have to go back as far...If you have to put it on its grab bar to load into a truck, the a longer grab bar won't work, the shee will fall back down..
I have an AC baja bar. Or whatever it's called. and a -2 arm. Here is a pic.
or two...
fc5ddf6a.jpg My silencers don't hit. I tip the shee up to wash it. no problems..... And I don't ever hit the grab bar in a wheelie. :unsure:
thanks boonman, I found out the dg wide bar is 1-2 inches longer to the rear then stock so thats what Im going with. All I need is like half an inch
