Optimal Performance Posted April 6, 2014 Report Posted April 6, 2014 Hi, my left cylinder is being a pain. I bought new plugs not wires, do the wires or ignition coil go bad often or just one side? I'm stuck on this and can't get this guy to run right. Please help! Quote
sangheraent Posted April 6, 2014 Report Posted April 6, 2014 (edited) did you try to flip the plugs/wires? if it switchs its electrical if it doesn't switch its your fuel or intake Edited April 6, 2014 by sangheraent Quote
984mmshee Posted April 6, 2014 Report Posted April 6, 2014 Explain exactly what its doin had a left side issue and ended up being carb related Quote
sawf414 Posted April 7, 2014 Report Posted April 7, 2014 Had a right side issue one time, turned out to be throttle cable. Quote
Larry's Shee Posted April 7, 2014 Report Posted April 7, 2014 Ohm plug caps seperatly. Trim 1/4" from plug wires. Clean any rust off stator poles and flywheel timing nub. Set pick-up gap at both nubs. Quote
thomas h. Posted April 8, 2014 Report Posted April 8, 2014 Set your float hights and make sure your carbs don't over flow Quote
