themechanic Posted April 6, 2014 Report Posted April 6, 2014 I have had this bike apart for a few seasons now and finally have the parts to put it together and for the life of me i cant remember where it was routed and what it hooked too. Cant find it in the manual either and parts micro fiche doesn't show it at all Quote
mxturd Posted April 6, 2014 Report Posted April 6, 2014 It routed up to a T i believe. Right under the tank Quote
do-work-son Posted April 6, 2014 Report Posted April 6, 2014 http://www.ebay.com/itm/Banshee-Clutch-Cover-Vent-Block-off-Plate-/110747369144?_trksid=p2054897.l5658 This works too Quote
Zillaguy Posted April 6, 2014 Report Posted April 6, 2014 I bought a billet plug and plugged mine. There is no need for it when you have a vent on the rear of the cases... Both are transmission vents... Quote
themechanic Posted April 6, 2014 Author Report Posted April 6, 2014 Going up to a tee makes sense, the only hose i had in the box had clamps on both ends. Im pretty down with blocking it to clean up the appearance abit though Quote
RagunCajun Posted April 6, 2014 Report Posted April 6, 2014 I believe i put a old small bolt in mine and clamped it off years ago. Quote
2004LEBanshee Posted April 6, 2014 Report Posted April 6, 2014 It goes up to a t that os above the carbs. I filled mine with solder and siliconed the hole. Quote
Coupelx Posted April 6, 2014 Report Posted April 6, 2014 you can cap it off. alot of us do, mine has been that way for along time. The motorcycles had an oil pump there. Quote
