crank and piston?
I was just refering to rod lengths and the odd 2T2 rod, that paticular rod has (I believe) a different oiling slot for the bottom bearing and was not intended to run as high of RPM or as hard as a Banshee is run so if thats the rod he's using it is 115mm long but may not be the best choice for a banshee.
  • 2 weeks later...
