It is a RMStator. And yes I tightened the timing plate.
Reason I asked is because I bought a banshee once and guy said same thing happened...ran for 2 minutes shut off and never started again...popped flywheel off and stator wasnt tight and the flywheel chewed through the wires
Well change your jets and while you got the carbs off clean your carbs and clean the hole in the pilot jet with a piece of wire or something thin enough.
