I have a ported stock cylinder motor on a stock t&w crank and I think one of the rod bearings went along with a piston on one side. So what is my best option? Replace, Rebuild, Time to go 4 mill??
So is it really just not worth buying a new stock stroke crank and doing the top end?
You can do that if you like, but for the money your going to spend on a new stock stroke crank ($400 trued & welded, FAST Racing price) for $50 more you can go to a 4mill crank and gain a lot more power once you have your cylinders ported correctly for the added stroke.
I did a leak down test and it held air all day.
It was knocking like a mofo. Pulled it apart to find a scared up piston and cylinder on the right side. And I believe I found the culprit...there was a couple grains of sand in the right side main and pilot jets plugging them.
  • 2 weeks later...
Ok, so I talked to Jeff and I am sending my cylinders in. He is going to see what can be done with them and If the transfers are too tall there may be a 4mil Serval in the future :)
