Assuming you have stock carbs, you need main jets somewhere between 230 and 320. Pilot jets somewhere between 25 and 30. Air screw somewhere between 1/2 turn out and 2 turns out. That's the closest we can get with the information provided.
Thanks but my elevation is at about 600ft
That's part of the puzzle but still need more. What carbs, temp you will be riding in, any mods done(pipes, porting, air filter style if stock lid on or off)? This info will help get a good estimate.
Stock banshee with stage 4 trinity pipes and stock carbs nothing else is done
as in stock airbox with full lid and snorkle? Temp?
probably around 27.5 pilot and 280 to 290 main. in between 1 and1.5 out on airscrews which ever gives the best crisp throttle response
