Jasonhammond2121 Posted February 19, 2014 Report Posted February 19, 2014 I have a 2000 banshee stock carbs, I just purchased FMF gold series pipes and FMF power core 2 silencers with K&N filter. I'm at 1200' elevation... What's the best jets and jetting to use? Please help need info I'm new at this, thanks Sent from my iPhone using Tapatalk Quote
uman1030 Posted February 19, 2014 Report Posted February 19, 2014 whats the temp youll be riding this in? what type of airbox, lid on or off or any mods to it. FMF also has a recommending jetting page. http://www.fmfracing.com/RiderSupport/JettingCenter although their recommendations may not be accurate depending on airbox mods Quote
Jasonhammond2121 Posted February 19, 2014 Author Report Posted February 19, 2014 Like 75-90 degrees, factory airbox no modifications. I was thinking about cutting some slits into the side of the airbox for better ventilation Sent from my iPad using Tapatalk Quote
Jasonhammond2121 Posted February 19, 2014 Author Report Posted February 19, 2014 (edited) Also I want to purchase extra FMF silencers with spark arresters, what is a good loud silencer to get? Or do they sell spark arrester adapters Sent from my iPad using Tapatalk Edited February 19, 2014 by Jasonhammond2121 Quote
uman1030 Posted February 19, 2014 Report Posted February 19, 2014 with your setup the FMF recommendations should work perfect. 30 pilot, 260 main 3rd clip position. airscrews 1.5 turns out. if you mod the air filter or run with out the airbox lid you'll need to increase the main jets edit: this is at 70 degrees 0-1500ft asl as per fmf site. may be a tad lean on main at higher temps by 1 jet size. Quote
Jasonhammond2121 Posted February 20, 2014 Author Report Posted February 20, 2014 Awesome thx I'll give it a try and will get back to you on how it performs Sent from my iPad using Tapatalk Quote
Jasonhammond2121 Posted February 20, 2014 Author Report Posted February 20, 2014 I went to the site and entered my year make and model quad and it brought up a FMF power up kit. Is that the one I should purchase? Sent from my iPad using Tapatalk Quote
uman1030 Posted February 20, 2014 Report Posted February 20, 2014 personally i would just buy the jets from a site sponsor. jets are usually around 3-4 bucks each. call jeff at Fast and he will hook you up and mail them the next day. http://www.farmandsandtoys.com/contactus.asp Quote
bluebanshee98 Posted February 20, 2014 Report Posted February 20, 2014 Don't buy the jet kit it's a waste of money all you need is the correct jets. Save $ for other things like suspension Quote
Jasonhammond2121 Posted February 20, 2014 Author Report Posted February 20, 2014 What's a good loud fmf silencer that has a spark arrester? Also does fmf make a spark arrester for the powercore 2? Sent from my iPad using Tapatalk Quote
uman1030 Posted February 20, 2014 Report Posted February 20, 2014 spark arrested FMF silencers are Turbinecore 2's Quote
kedge82 Posted February 22, 2014 Report Posted February 22, 2014 fmf sst's have built in arrestors and are approved for forest riding but you must buy set other silencers do not work with them propely and they sound desent it think anyway Quote
